Thinking Of Running 4 runs of wire, 2 power 2 grounds need some help
crfrider
A yes I have one run of knu klmx 1/0 to the back battery, now I had it just grounded in the back but im going to run a ground from the front battery ground cause i heard its better, well im thinking of going ahead and adding 2 more runs, 1 power and 1 ground, would this help charge faster buy doing this? also what if I ran one of the power wire straight to the alternator would this be better
It really depends on the resistance of your car and the quality of the grounding location.
I would take a meter and wire and test the resistance of you car's ground path (rear grounding area and negative battery terminal) before you pull the trigger on buying more wire.
crfrider
crfrider
Oklahoma
Atimm693
