thinking about mixing components.
flakko
Veteran (my butt)
10,845
So Cal
okay...
if i get some 5.25" contours, and just use the contour tweeter and keep my soundline mid woofer, will it have better results than just ditching the soundlines altogether, and use the entire contour set?
i have a space problem, so will the 5.25" midwoofer sound just as good as the 6.5" soundline woofer even though the soudlines are a step down?
im just throwin out ideas here.
Go for it.
If you don't like the results, you should have no problem selling them (and most likely turning a profit) on E-Prey.. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Go for it.
SHHHHHHHHHH!!!
go for it- the contour tweet alone is reason enough to consider it an upgrade //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
awesome... how about the midrange?? will i get better response from the contour (5.25) or the soundline (6.5)?
My guess is that you'll see better midRANGE out of the 5.25" Contours..
But what do I know.. //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
erm
wat about the midbass, will i miss out on any frequencies if i crossover at the same place?? its a smaller higher line compared with a bigger lower line...
you'll apreciate the larger driver in the lower midbass frequencies, but 5.25's are quite capable and can yield nice results- worse case scenario you can use either with the better passives no biggie
or active.
hopefully there is\are no problems with a passive that is made for a different speaker and the xover\slope\freq response is OK.
or active.
oh crap... i forgot about that....
I would just say if you're going to mix components just make sure that whatever tweeter you're using that you use the passive crossover that the tweet came with seeing how in a 2 way set the hi-pass for the tweeter is the most important.
okay what would you reccomend?
While I have never heard the 5.25in. Contours, I can tell you that my 4" Pro's ROCK !!!!
I just got done installing them in deadened Q-Forms in my truck. Currently crossed over at 150hz (I'm going to play with that), they sound SUPERB! I'm only sending them 100 watts rms and they don't seemed fatigued at all. Plus they are so smoooooooooooooooooooth.. Like J-Lo's back side. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Cranking them up only produces crystal clear music. Harshness is now a thing of the past! So long distortion, it was nice knowing ya'.. NOT!
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif//content.invisioncic.com/y282845/emoticons/veryexcited.gif.c26a15f316d23068607f36ddacd7a7ab.gif//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I was thinking maybe the xd series similar magnet size and same surround and voice coil 2.5
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
10
Im not sure if this helps or is the correct way but I have 6.5 mids in the front doors and tweets in the pillars I used 2way 6x9s in the rear...
988
Lower price Subs: $275 shipped Only selling one set of 6.5, keeping the other $100 shipped
845
flakko
Veteran (my butt)
flakko
So Cal
3.5Max6spd
Brendon Jenness
    May 8, 2024
    May 8, 2024
