Thinking about doing a 3 way setup.
Buck
little alien on campus
I will probably sell my boston sl80s and get a nice 6.5 component set and put the mid in the door and the tweeters higher up in the door. I was also thinking about using some 6.5s (like eDs 6.5) to use as a midbass and locate them in the rear doors. Now I'm not going to be competing, I'm just using the locations I have. Just looking to get a full range of sound during daily driving.
It's like when they asked Austin Power's what his *** was and he replied "Yes please!"
OP - you cant just start adding drivers to your "stage" like I think you're intending to.
Get a very nice comp set, run it active and be done. 3 way setups are quite rewarding, but can be tricky to set up. If you want to still consider doing this, I would suggest tweeters and mids mounted on the A pillar and midbass drivers (8s) mounted in custom kick panels.
Mr Bang, makes a good point, how are you going to bandpass the midbass?
How about this, a Sundown 50.4 powering the A pillars, and a 125.2 pushing the midbass? Amps have the built in crossovers to cover the speakers, but that setup will lack the finesse as if you had done the same thing with a HU that had active abilities, and offer less control from the driver seat.
Just a suggestion...
Buck
Buck
Inside of a pyramid
Megalomaniac
