Think it is possible?
indosia
You think it's possible for your cylindar head bolts to come loose form excessive vibration? I mean, can to much bass loosen the bolts holding your engine together? //content.invisioncic.com/y282845/emoticons/idea.gif.5acb6a39a9b92425414c316dda202bad.gif I think maybe it can. FIrst i lost a cylindar then the car started smoken so much i couldn't even drive it. It was an 89acura legend. And this happened 2 years ago.
My fuse box fell apart, and my fender cracked a lot worse since my car got a system (plastic Saturn :p)//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif But not a chance in hell any structural stuff like head bolts or anything like that will come loose.
Hey man did u ever think that ur car being 13 yrs old might have had something to do with it.things like that happen to old cars.
Sounds like your heads weren't bolted down correctly to the right torque specs. Or whatever thread lock that was used on the factory manufacturing has broken due to age and has continued to loosen up over time
Anyone who attributes loose engine bolts to their system needs their head checked. Umm... folks... the engine vibrates itself worse than any system could ever vibrate that large a chunk of metal. If you are losing head bolts, then either they were incorrectly torqued, they were not Loc-tited, the block or head cracked at the bolt, or the gasket blew and left enough space fo the bolt to start working itself loose from engine vibration.
indosia
indosia
hayward, ca
helotaxi
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
