some of the chevy400's sucked because the walls between two of the cylinders was too thin. this led to problems. i dont know which years they were. if you took a 350 block and just put the 400 crank, 5.7 rods and stock 350 pistons in it would be 377 c.i. to make it a 383 it is the same parts but!!!! the motor is bored out .030 larger( slightly larger bore gives you the few more cubic inches and you use .030 larger pistons. but reguardless, you can have all the power you want out of a plain old 350 believe me. it is easier to deal with any parts you end up wanting to change, you will get the experience of building a motor and beating it sensless. btw. the last fast car i had was an 82 firebird se with a 350 .030 over bored, a comp cams 268h grind cam, 9.5/1 keith black pistons, chevy pink rods( lt1), an old set of 194/160 chevy heads with a mild port/gasketmatch, a 69 z28 replica intake manifold, and a holley 600cfm with vac secondaries. i did a 380 hp at the wheels which equates to about 430 at the crank and i built it myself!
What are the positives of building one of these over a regular old 350? Just alot of torque? Would it be worth it to bore it out more than 30 over or does that kind of cancel stuff out? If I was gonna build one and bore it out I would definately bore it out more than 30 over. If you bore it out enough should you just build a 400 with 350 heads or does the 350 have thick enough walls to bore it out enough to make it bigger than a 400.
Thanks again..
