they sound very very bad
ZmanTT
tx
please help me out here, heres the situation i just intalled 2 4X6 in the front dash and 2 6x9 in the back i had to cut holes for the 6x9's and i put room insulation in with all the speakers....i'm running all of the speakers off the head unit (55X4) and i used 24 gauge wire to go to all the speakers i tightened the speakers down as tight as they would go but they are not fush against the board and i just wedged the 4x6 in so theres gaps on all four speakers....and honestly it sounds like ****, is there anything i could do to help the sound? i know this is a really ghetto set up but u think u guys could help me out, peace
24 gauge, isn't that a little small? i'd go to like 16 or 14 gauge, but that shouldn't have to do with anything about the quality. what kind of h/u do you have?
Originally posted by ZmanTT please help me out here, heres the situation i just intalled 2 4X6 in the front dash and 2 6x9 in the back i had to cut holes for the 6x9's and i put room insulation in with all the speakers....i'm running all of the speakers off the head unit (55X4) and i used 24 gauge wire to go to all the speakers i tightened the speakers down as tight as they would go but they are not fush against the board and i just wedged the 4x6 in so theres gaps on all four speakers....and honestly it sounds like ****, is there anything i could do to help the sound? i know this is a really ghetto set up but u think u guys could help me out, peace
maybe your speakers are out of phase
thanks guys i really appreciate your help, so will upgrading all the wires to 16 gauge and sealing in all of the holes....with maybe then it should sound a lil better? if that will help then i'll do it in a second....
get a 4 channel amp
yeah i was gonna get a JBL 80.4 for the speakers but i wasn't sure if it was gonna make the sound much better for 130 bucks but if it does i will do it.
i have a blaupunkt BP655....i know its not the top of the line or anything but i got it for cheap with a life time warrenty / and is the 24 gauge keeping alot fo the potential for the speakers back?
what does that mean?
but anyways thanks again, peace
It means one speaker has + to + and - to - like it should, but the other one has + to - and - to +.. so it's getting a signal that has it moving in the opposite direction of the other one at any given point in time.. The implication is, make sure all the speakers are wired properly (or at least the same)..
Hope that helps..
"I don't have any crossovers" You'll need one to filter out the low frequencies leading to your sub woofer. They'll produce no sound then...
14
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
6
215
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
ZmanTT
ZmanTT
tx
Moocow16
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
