these box calcs seem right?
well the box is 22" front to back on the outside and i used 3/4" mdf so its 20.5" internal front to back.
okay, i looked up some of jmacs posts and im still getting closer to what i said.
Originally Posted by Jmac
Meh, calculators **** ... Use a sheet of paper and a pen, draw out your enclosure, make sure it's right ...
Here's a step-by-step process of how I do it ...
1) Measure your trunk for max dimensions and note TWO dimensions that would be preferable. Subtract twice the thickness of the desired dimensions to get the desired internal dimensions (i.e. 3/4" MDF, 20" height = 18.5")
2) Figure out desired net volume, tuning frequency, and port area.
3) Figure out port length using the following formula :
Lv = Av*1.84*10^8/[Vb*1728*(Fb/0.159)^2] - 0.823*sqrt(Av)
Lv = Port Length in inches
Av = Port Area in square inches
Vb = Net Internal Volume in cubic feet
Fb = Desired Tuning Frequency
4) Draw out a diagram of your enclosure on a sheet of paper and figure out the displacement of the port.
5) Add up all displacements (port, driver, brace)
6) Add displacements to desired net volume and multiply by 1728
7) Divide by the two desired interal dimensions to get the third internal dimension
8) Add twice the thickness of the wood to get the exterior dimensions
okay the box is 28"w x 22"d x 18"h. this comes out to 5.187 cubes internal before port/sub/bracing displacement.
So i took his formula for port length and here is what i got:
40*1.84*10^8/[5.187*1728*(30/0.159)^2]=23.0658555219959
So where are uo coming up with these longer lengths? Please help me.
okay i see that. Now how does this relate to port height and width? Im sorry if this is a dumb question. The port is 3" wide x 16.5" tall. so how does that relate to the square inches? You guys had told me like 40 or more inches in the beggining of this post????
okay so...
49.5*1.84x108/(5.187 * 1728 (30/.159)^2) - (.823 * sqrt of 49.50 ) =17.2755372569959
so a 17" long port?
okay, well im glad thats all cleared up. I originally had 22.65" using winisd. So where did xtrememeasures come up with 42" port length? Well im glad i can finish building my box now the way it was originally planned //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif You guys had me thinking i was so off before. Thanks for the help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well thanx bro. I misunderstood you and i apoplogize. Ive been going crazy all week trying to figure out this port stuff and im just glad it makes sense. If you could do me a favor, what is the displacement or at least how do you get it? Or better yet, after port dispacement and sub (.18) and a little bracing will i have around 3.5 cubes or more?
exterior dimensions-28"w x 22"d x 18" h
port wall 1-16.75*16.5
port wall 2-5*16.5
5.15*3.75*16.5 = 318.6 ci
18.5*3.75*16.5 = 1144.6 ci
Total = 1463.2 ci
=.846759 ft^3
sub box= 5.187 internal
- sub displacement (.18)
- port displacement (.846759)
=4.160241 cubes tuned to 30 hz. Still got to subtract a bit for bracing.
if i am incorrect on any of this, please fell free to correct me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif also, i would like to thanks jmac because even though he never got back to me on some questions, i was still able to dig up some of his posts and find some very uselul formulas.
wu501
wu501
N.Y
OLD_SCHOOL
vegang
vegang
