The What? and How?
518wrx
ok im second guessing the equipment I have to see what amp im going to keep. I have a Memphis st1000.1d 1100watts at 1ohm and an Orion xtr900 .
what i need to know is which amp would give the most spl and how many ohms i should run and how to run the wiring to the amp from the speakers (2 Memphis m3 154d 4ohm dvc 15")
Orion specs:
Xtreme 9002
Output Power at 13.8V, 20Hz ∼ 20kHz,
2 x 225W @ 4 ohms
2 x 450W @ 2 ohms
1 x 900W @ 4 ohms bridge
THD:
Freq. Response: 20Hz ∼ 20kHz (±0.25dB)
Linear Bandwidth: 6Hz ∼ 50kHz (±3dB)
S/N Ratio: >100dB (full bandwidth, rated power)
Damping Factor: >400 (at output connector, full bandwidth)
Fuse: 2 x 30A
Dimensions: 18" x 10.25" x 2.25" (45.7cm x 26cm x 5.7cm)
memphis specs:
1100 @ 1ohm
600@2ohm
400@4ohm
any help would be greatly appreciated, i need to get this going ASAP
What are the advantages or disadvantages to using different ohm levels? Also,does it matter if you use a different ohm then what manufactuer specified on speakers, If I am correct all pos and neg wires should run in a chain to amp for 1 ohm? Also, how would I run wiring for 4ohms just for further reference....
Thanks again guys.
518wrx
518wrx
Albany,NY
undeadxsunshine
