The King Of Amps Has Arrived!! THE WARLORD
Ok guys the uk Price for the WARLORD is £1650 for COMPETITOR price pm me or email me at andrew@adassaaudio.co.uk competitors must have a stats page and compete in meca or db drag and anyother formats the prices for the uk r gonna be different prices than in the us we r trying to work out a price that is suitable for every1 in the uk us and other countries.
Well whats the UK price? Ill convert it.
Ok so i was just sent the manual. here are the manual features and specs
FEATURES
Digital Class D Linkable Mono Block Amplifier
Daisy-Chain Through Output RCA
Dual MOS-FET PWM Power Supplies
Stable into 1 ohm and 2 ohm Parallel Amplifier Connection Availability
24 dB Low Pass (LPF) Crossover Variable
18 dB Bass Boost Equalization Control Variable
180 degree Variable Adjustable Phase Shift
24 dB Subsonic Filter Variable
****Selectable Switch for MASTER and SLAVE operation****
Speaker Short, Over Current, Thermal, and DC Portection Circuit
RCA Line Input and Line Out
Heavy Duty Cooper Layer Double Sided EPOXY PCB
2 x 0 Gauge (AWG) Battery Input Connectors
100% QC Testing and Warm UP
Efficiency: 86% at 4 ohm, 100hz
Operating Voltage: DC 10V ~ 18V Power Input
Damping Factor: Better 350 into 1 ohm
Wired Remote Bass Gain Controller with 5 Meter Flat Cable: Optional
SPECIFICATIONS
RATED POWER OUTPUT
RMS Power 1 ohm (12.0V)-------------------------------- 3400W x 1CH
RMS Power 1 ohm (14.0V)-------------------------------- 5000W x 1CH
RMS Power 1 ohm (16.0V)-------------------------------- 5900W x 1CH
RMS Power 1 ohm (18.0V)-------------------------------- 7500W x 1CH
2 SAME UNITS PARALLEL LINKED
RMS Power 2 ohm (14.0V)-------------------------------- 9900W x 1CH
RMS Power 2 ohm (16.0V)-------------------------------- 11800W x 1CH
RMS Power 2 ohm (18.4V)-------------------------------- 14900W x 1CH
Signal to Noise Ratio ---------------------------- >100dB
Low pass frequency crossover ---------------------- 35Hz~300Hz
Subsonic filter ------------------------ 10Hz~60Hz
Bass boost @ 45Hz------------------------------ 0~18dB
Phase Shift Control -------------------------------- 0~180 degree
Frequency Response ------------------------------ 10Hz~350Hz (+/- 1dB)
T.H.D. @ 4ohm ------------------------------
Efficiency @ 4ohm -------------------------------- 86%
Fuse rating ------------------------------ 250A x 2 (External Type Fuse)
Input Sensitivity ------------------------------- 200mV to 6V (+/- 5%)
Dimensions ----------------------------- 270(W) x 65(H) x 620(L) mm
The above specification shall be modified by manufacturer for improvement without prior notice
Pure sexyness, I can't wait to see what happends when you get all this shit installed, I sure hope you have access to a TL man //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
Road trip to me and jump on the meter!
ill be moving to arizona on november 15th or so. give or take a few days. so i wont do the install untill i move out there. plus my amps wont be in for awhile. im in no real hurry YET. untill then ill just put one of my ma audio 18's and a 800 watt amp in just to get by.
I can almost bet the performance will be around the same //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif the adassa and the AT's original board. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif :yumyum:
2000LaDe
2000LaDe
Lafayette, IN
snoopdan
