I hope you didn't find my comments offensive before as I only wanted to help better your testing. I think you are definitely going in the right direction with this now. Especially the testing in the room there. The only thing I would suggest with that is to have the cabinet on the ground with mic also laid on the ground. The reason is because you get the first reflection off the floor that will cause ripples in the curve based on the time difference the sound takes to go from box to floor to mic. If you only plan to measure to 80-100hz this may not be an issue. The larger this distance, the lower in frequency it effects the response though so making the reflection occur quickly is much better for subwoofer measurement. With the mic on the floor you'll be able to measure accurately up to the 1/2 wavelength of the microphone diameter. I can get to around 5KHz or higher with the mic I have using a ground plane measurement. You'll then be only limited by the distance to ceiling and back down or walls to mic. Putting the cabinet in the corner optimizes the room as the reflections occur right away and only affect the higher response. Here is an example of measurements done in this ground plane style by Mark Seaton for the AV123 HR UFW-12 with our driver in it.
http://www.av123forum.com/showthread.php?p=672192#post672192
In any case, I'd be willing to put in an AV15H into the mix. Let me know what impedance you're interested in. We're just up in GB so you'd be welcome to come up and get the quick tour of the shop, or I could run one down to you. Let me know.
Also I didn't see in the latest post, but for the vented boxes at 35, 40, 45hz, where are you setting the highpass filter?
John
