LoL. You guys need to read. 2012 has something to do with time.
You see, in this life you have one conscious focusment. It has to do with a linear system of time where you "believe" and are convinced that all that you can perceive is the present happening. In 2012, our consciousness changes and expands to allow us to visually see the past present and future. There will be no more linear perception of time. That is really why the Mayan calendar ends. It ends because the linear perception of time ends on that date.
It doesn't have to do with the "end of days" or the "end of time" and us all dying. It has to do with the expansion of our time perception.
That is why all calendars are linear. They are linear because we try to explain everything objectively.
Everything you know right now is about to change because your consciousness is going to evolve.
It's not really going to evolve, but expand. The word evolution is a derived from the idea that time exists. If you take away these limited assumptions of what you learn about time from the society and the school system. It can make sense. You first have to convince yourself that time does not exist. Because it doesn't. You only believe it exists and is moving forward because of what you picked up from interaction with other members of the reality. You all agree it exists, so therefore, it only seems logical to assume it does
You then accept it as having more power over you and believe you are subject to it. Truth is, it is still a by product of our consciousness. We are not subject to time. Time is not an external force. We ourselves are in control of time and the flow of time.
All 2012 has to do with anything is perception expansion. I would not say evolution because then, I myself would have to accept time as a stronger, more powerful force than I myself.
I know about time expansion because I can do it. I learned about it. I learned how to practice it. And now I can control it. Everyone reading this message can do the same. If you decide to discard the limiting belief.
You first have to become a student of such studies and then realize you are the master of your reality. You are not a victim walking the linear-line from birth to death, you are not subject to time and space unless you believe you are.
It all draws down to what you believe. If you change your belief system around, examine your beliefs, and try to spot where the belief originates, you yourself can then sit down and decide whether that belief is suited to your best interest or not. Most people running around in the society victimize their selves because of poorly assembled belief systems. They don't realize the leverage of a belief so they unconsciously use their beliefs against them. Where as somebody who is in tune and understands uses their beliefs in their favor.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif No sir... You can walk around thinking that time is not a product of the reality of the world you live in all you want. And when you die in a car wreck or by a heart attack, or even just natural consequences I will stand by and laugh at that notion.
Time is a product of reality and its just as real as holding an object in your hand. Actually very similar. Most people think of an object having length, width, and depth. But there is a 4th way to measure objects through time.
The only thing you can become a "master" of by changing your state of mind, is your perception compared to those around you. (fyi not the process of decay on your body) but you can change how you percieve the progression of time compared to others.
However my entire point in everything i've said boils down to this, changes in perception, location, and velocity relative to other entities, are completely irrelevant. This is because everything is also relative to the speed of light at a different but equal ratio...
The mind can change how you percieve reality, but it does not change the world around you, it only changes you... So yeah you can become what we call "crazy" however i believe that "crazy" isn't necessarily a bad thing, because you are allowing your mind to understand perspectives other than your physical own.
But, this is essentially useless unless you can return to your previous form of perception on the same plane as reality and apply the insites you obtained to this perception.
IE: Ever seen patch Adams? when he is in the mental institution the old genius helps him to change his perception of reality, (by seeing 8 fingers on his hand)
however his mind was able to "come down" from this perception and apply the concept to his life which made him appear to have very innovative ideas.
If had stayed in this alternative state of perception, he would've stayed in the mental institution and died the same way every other human does.
