The Big 3
Ruckus - i'd say go 250amp fuse. Even if you get a HO alternator later, you wont have to change that fuse, unless you get some crazy 250+ amp alternator.
95Prober - The big 3 is the electrical equivalent of the cars intake/exhaust system. The faster electricity can flow through your car, the more power your amps can produce. When the flow is restricted, your amps try to pull more power and that takes away from the other electronics in the vehicle. It is most noticeable in your headlights(dimming).
Is your alt+-batt+ wire running through the fuse box? If not, I'd say dont touch the fuse box. They are fused that way for a reason and you aren't increasing current draw to anything that has a fuse in the stock fusebox.
so bascially, it to increase the flow of electricity/power to your amps and throughout your car so things can get powered faster and easier ??
also preventing headlight dimming in most cases?
the bigger the wire, the less resistence, so the easier it is for power (CLEAN power) to get to your amps and other electrical needs.
Question if my alt wire goes to my fusebox and then a wire to the battery cant i just bypass that and go directly alt to batt?
You should be able to, yes. Just add the direct wire on with an external fuse and don't touch the one running to the fusebox.
Ok my alternator wire goes to fuse box then from fuse box to battery where do i put an additional fuse? i already changed the fuse box-battery wire to a 4ga i believe.
You don't in that configuration. It's already fused with the box. You would only put an additional fuse if you made an additional direct run alt+ to battery like I just stated in the last post.
not a good idea if that wire were to short you may have a potential fire
just replace it with the old wire and run an extra wire from the alt to the batt
Damaso87
iPoor
Damaso87
Springfield, MA
Mr. Opportunist
vegang
vegang
