it should be fine. Unless you get into a car accident you really shouldn't have any problems with that wire shorting out.so the 150 amp fuse will be good for sure between the alt and batt?
Unless you removed the voltage regulator from the alt your not going to overcharge your battery, therefore it's not going to explode. The voltage regulator will send the correct amount of current to the battery as it's needed.Ok cool. The main thing the fuse is for is to stop overload of current to the batt right, to protect it from exploading? So 150 amp fuse will stop excess? Im confused on how it works a little bit
although he only needs 75 amps for the amp, if he's going to fuse the alt wire then he needs to think about everything else that the alt is going to cover too, like the A/C, radio, headlights, wipers etc. Each of those add to the total amp draw from the battery, in turn drawing more from the alt. So the amp might only draw 75 amps, but with all the other items that need power too the draw can easily reach 150 amps.He has a 130 amp alternator and only needs 75 amps for his audio. 150 amp fuse is fine.
