The best way to Big 3????
swalk386
im a noob to car audio. i want to upgrade my electric so im debate which would best.
either install a second alternator and have that directly hooked up to my second battery
or upgrade my current alternator
its for an ford ecape 4cyclinder and extra battery is from a Grand Marquis
I have a hifonics 2608 i plan on upgrading my amp so i can get subs that has 2000 rms
First off to be to do the big 3 with the biggest wire you can get your hands on and then I would how bad the voltage drop is.
If it drops to low then I would upgrade the alternator but I wouldn't add a second alternator...
Also, you can run multiple batteries off one alternator.
in to see this extra battery. please tell me you arent putting a wet cell battery inside your car. also //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif there is a sticky on the big 3 already man. little search wouldve easily found it
First off to be to do the big 3 with the biggest wire you can get your hands on and then I would how bad the voltage drop is.If it drops to low then I would upgrade the alternator but I wouldn't add a second alternator...
yea i have been running both batteries off my stock alternator but my lights still dim a lil with heavy bass songs only tho
i have 0/1 gauge wire running from my stock battery to my extra battery in the back in line fuse
and yea i put a wet cell battery in my car.....it may not be the best thing to do but its working
It will kill you
I hope you never take your kids, if you have any, with you in that car or anyone you care about. by all means go ahead and breathe in all the sulfur you want //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
This is true.... get that **** the **** out or die... literally
swalk386
swalk386
Deltona, FL
Pborcich
