The Best, Loudest box. Plans Please
I need ideas on the best box you can possibly make. It needs to be for one 12".
Thanks
ok whatcha wanna do is tune the box to 22hz with 100sq. inches of port and the box should be about 3 cubes //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
or better yet go with 5 cubes @ 60Hz make your port about 10" wide, stick your head in and blow it up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The main thing you should take away from this experience, is if you do not know how to get something, then ask, OR, READ AND RESEARCH????? We love to help, but there is so much mroe to designing an enclosure then putting wood together and saying, vuala, it's the best and loudest. And if loudest is what you want, then your best bet would be bestbuy because you obviously care not for quality.
don't listen to them they're just assholes.. heres some plans for ya man:
duct tape a shoebox (size 12) shut (lid and box) so that it is airtight. you can stiffen the box beforehand by taping toothbrushes in rows so that the box does not flex (you can use popsicle sticcs if u dont have extra toothbrushes). after duct taping the box airtight cut a hole using scissors and a lisa frank stencil. drill a hole in the bac of the box for the wire to go through by using your hands to create a drilling motion with a sharp pencil. be careful not to drill a hole in your hand.. it can be very painful and lead to lead poisoning. now place your woofer inverted yes inverted (this is an inverted box design) which means the cone should be facing the inside of the box and the magnet should protrude outside. attach the woofer to the box using staples and use krazy glue to seal the gasket to the box. voila! you are done. nowpaypal $5 to l2smog@yahoo.com
+1 FER JOO!
garrett58
garrett58
grover beach, CA
garrett58
