The Batmobile 4th order! 2 18's!
Kryptonitewhite
What subs should we use for 4th order BP? We want a LOW tune around 25Hz-30Hz. Plenty of airspace available, 2 20"x20" square ports. 2 18's. Run off either one or two AP30001Ds.
holy shitty ripoff batman!
all you need is a batsignal in that ***** to get some mad tang on the streets. In the hood... area of a junkyard.
Exodus Audio Maelstrom-X 18"
1) Speaker Parameters
Diameter: 18.00 (inches)
Qts: 0.37
Fs: 17.40 (Hz)
Vas: 11.05 (cubic feet)
= 312.90 (liters)
S: 0.70 (response curve - .4 thru .7)
2) 4th Order Bandpass Cabinet Parameters
Lower 3db Rolloff: 20.00 Hz (F3 Provided by user)
High 3db Rolloff: 53.89 Hz (Calculated)
Sealed Box: 4.32 cubic feet
= 7458.70 cubic inches
= 122.24 liters
Ported Box: 2.96 cubic feet
= 5122.98 cubic inches
= 83.96 liters
Tuning Frequency: 32.83 Hz
3a) If using a Single Port
User definable port size:
Port Diameter: 8.00 inches (203.20 mm)
Port Length: 36.47 inches (926.43 mm)
Suggested: (.3 X Speaker Diameter)
Port Diameter: 5.40 inches (137.16 mm)
Port Length: 15.33 inches (389.47 mm)
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
871
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Kryptonitewhite
Kryptonitewhite
soo foo sd
Kryptonitewhite
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
