The bandwidth (BW) of an amplifier
kiranmai
hyd
The bandwidth (BW) of an amplifier is the range of frequencies for which the amplifier gives "satisfactory performance". The "satisfactory performance" may be different for different applications. However, a common and well-accepted metric are the half power points (i.e. frequency where the power goes down by half its peak value) on the power vs. frequency curve. Therefore bandwidth can be defined as the difference between the lower and upper half power points. This is therefore also known as the −3 dB bandwidth. Bandwidths (otherwise called "frequency responses") for other response tolerances are sometimes quoted (−1 dB, −6 dB etc.) or "plus or minus 1dB" (roughly the sound level difference people usually can detect.
mazda 6 cars
used cars for sale
kiranmai
kiranmai
hyd
TMali
