The Art of Box Making
Perfect cuts every time.
You can use that same method except angle the blade on your saw for your 45* cuts. Then cut the pieces to length.
thats how i do it. awsome
Well today Im going to pick up some things from Lowes to start my build for my 2 12" HDC3's tomorrow. Also to pick out a new circular saw my girl is getting me for Birthday;). So Im more or less looking for pointers or any techniques people use into making these boxes. They seem straight forward, only thing that bothers me is how do you cut the wood, or even cut it with, that goes into the corner of the box that helps with the air flow. I know its suppose to be at 45 degrees, but is there a special tool you use to achieve that? Also does anyone have any recommendations on glue, circular saw, jigsaws, etc. they use and like.
Enellz
Get a Tablesaw. /thread
Nah, you need a guide... and a good design.
As for the 45* angles, most people don't do it properly... and it ends up being more of a detriment than a help. You're SUPPOSED to make it so that the port is the same width through out the whole port. (That's the point of them, and to ease the moving air for the turn) You have to cut the other side of the port to make sure the port is the same size through out the whole box. It takes a lot of work, actually... a lot of miniscule cuts to get it perfect... which most people don't do... and it ends up bottle necking the air.
But the 45* angles will be tough with a table saw. Unless you make them wide, then it won't be too bad... but you'll have to take more off the other side of the port.
VERY true. You're one of the few people that seem to know that.
OP - Check it...
I actually learned it from you. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I saw one of your threads and I was like, "Wow, that's really dope." Then I realized that if you don't do that, the port width isn't the same through out, so it ends up compressing at the elbow.
your first box most likely won't be that great and will need lots of caulk(unless you have an awesome table saw with huge extensions on it) The more you build the better they get.
I actually learned it from you. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifI saw one of your threads and I was like, "Wow, that's really dope." Then I realized that if you don't do that, the port width isn't the same through out, so it ends up compressing at the elbow.
Haha, that's some funny shit.
Not only does it affect flow (even if it is just minor) but the port area changes, thus changing the tuning.
When measuring port area for square ports, width is obviously a factor. When calculating, you're assuming the width is the same the whole way through the port, giving you an accurate port area, and your desired tuning frequency. If the width is changed at all, it changes the area.
This may not be super important all the time, but for the amount of times that i've seen it neglected, it worries me.
Enellz
The Triple O.G.
Enellz
Louisville, KY
snb778
