::TESTED:: Audiopipe AP30001D
I have it at 1 ohm but only in 1 channel so im only doing 1500w. I dont know what my voltage drops to cause I put my dmm on the back battery during bass hits and its all over the place and not accurate at all.
What do I need to do for it to work? my back battery is at ~13.8 when my truck is at idle.
you could have bad grounds to bad terminal connections. also might have a bad cell in eather battery. you do have them relay isolated right? if ur voltage is dropping below 11.8v you need to go thru it and make it beefier...
vehementSPL
vehementSPL
indianapolis
Wingman0121
