::TESTED:: Audiopipe AP30001D
I've been doing some reading about them and they do seem to be a great bang for the buck....I'm sitting here thinking I could sell my SAZ1500D and get an amp that puts out twice the power for pretty much what mine would sell for.....HMMM!!!
^ your meter is +/- 3% PLUS 8 counts (or something like that).. it works out to a lot more then 3%...
Your assumption that if you multiply the volts and amps you are reading you will find wattage is wrong.. I'm guessing that you either did not bother looking up power factor on wikipedia like I suggested, or you didn't understand it..
It may be the same kind of test everyone else uses.. so congradulations.. you are just as misinformed as 99% of the rest of the kids on caraudio forums..
this is late apparently but...
my sub is d2. is it possible to run each coil to each side of the a/b of the amp
or is this amp not setup so both parts are ajusted exactly the same ?
kind of like strapping it to its self ?
what?
this is freekin me out man. hahaha.
my sub is d2. is it possible to run each coil to each side of the a/b of the ampor is this amp not setup so both parts are ajusted exactly the same ?
what?
you could just wire the sub to 4 ohm and bridge the amp,
would to the same thing.
That's impressive, given that they are relatively cheap (not quality, I mean money wise).
I'm pretty close to getting AP15001d to run @ 1ohm for a pair of AQ SDC2.5 15"s
I'm sure the sdc2.5's will be satisfied with about 750w in 8.5ft^3.
Found the AP15001d for $165. I figure it's a steal considering I want a loud daily driver and I'm on a budget.
audiopipes website sucks ***....im not finding the info that i need on this thing...
is it a dual mono?(2 mono in 1 case)?
meaning that each mono is 1 ohm stable?
EX. a dual 1ohm sub...1 coil to each channel so that the amp is seeing two 1 ohm loads...would this thing be stable?
audiopipes website sucks ***....im not finding the info that i need on this thing...is it a dual mono?(2 mono in 1 case)?
It's 2 ap1500's 1 ohm stable in one case so I think your example would work just fine. I seen Terra say earlier about those Salem guys claiming 19,000 volts //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I doubt you can get that but they did hit a 159.x that night with it.
They had it in an electric truck. And they had the volts way the hell up there on it. So I'm pretty sure it has an unregulated power supply.
vehementSPL
vehementSPL
indianapolis
Wingman0121
NorthFramingham
    Jun 30, 2026
