test results 4000d
365. soemthing something amps of current draw at .25. now 37 amps at the subs and 80 volts do the math //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif dropping to 11.8 volts at the amp.
heres some pictures of the setup.
ummm id think noone trusts your results as your retarded.
i may talk ish but i dont lie.. ask thunder9500 he runs the amps so does a couple of his freinds i am not sponsered by memphis cause i havnet accomplished anything. so no reason for me to lie. if i find a stronger amp then you will see the 4000d on sale. i will say im getting more power out of 1 4kw then 2 powerbass 3000ds.
I don't doubt the numbers. I have 4 of these amps and let's just say they are the strongest amps we've put our hands on for our application.
so your boxes are a scam?
SARCASM
One entry found for sarcasm.
Main Entry: sar·casm
Pronunciation: 'sär-"ka-z&m
Function: noun
Etymology: French or Late Latin; French sarcasme, from Late Latin sarcasmos, from Greek sarkasmos, from sarkazein to tear flesh, bite the lips in rage, sneer, from sark-, sarx flesh; probably akin to Avestan thwar&s- to cut
1 : a sharp and often satirical or ironic utterance designed to cut or give pain
2 a : a mode of satirical wit depending for its effect on bitter, caustic, and often ironic language that is usually directed against an individual b : the use or language of sarcasm
in memphis eyes i havent accomplished anything.. all ive done is a 150.9 in street b but that was months ago old way different setup. that setup would do a 152.1 in stret b but i found out the hard way not to tune at night in cold temparature when at a show its hot "tunning changed"
ps i used to run 4 powerbass 3000ds and did that 150.9 i got one 4000d lets see what i manage with that single amp at the next show. oh yah and powerbass gots a 4000d now. i might get my hands on one;)
oh yah and carlton and a select few competitors i know.. know the reason why 1-2dbs louder no bs and tcab knows the owner of realm knows
1loudsuv
WHATS A HOME THEATER?
1loudsuv
west
btnhfan
michigan born
    May 14, 2026
michigan born
    May 14, 2026
