If the subs are gonna share chamber space you should have it easy..
One terminal cup (only one set of wires going in if you wire the subs together).. Speaker wire inside box from cup to speakers..
You will have to wire each sub parallel, and put them in series with eachother.. parallel on one sub drops that sub to 1 ohm, seriesed 1 ohms gives you 2 ohm..
You will have + on one sub, - on the other I believe.. sub 1 is + to +, - to - (both subs look the same that way, parallel on the voice coils), then from sub 1 + to sub 2 -, sub 1 - to sub 2 + (series the subs together).. sub 1 gets + from amp, sub 2 gets - from amp..
If this is wrong, SOMEONE TELL ME (AND HIM) BEFORE HE BLOWS SOMETHING UP //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
This means, don't do the wiring like I suggested until someone confirms this (make sure you know they are worth listening to, there are some here that are idiots and you shouldn't listen to them at all ... ThunderTunes for example...)
Hope that helps (and is right)
