Terminal Cup
the terminal cups ive bought from radio shack dont seem that great. they leak air... so ive stopped using cups. i just drill a hole into the side of my box barley big enough to run the wire, then i use liquid nails or some other caulking and seal it up. air tight that way, but looks a little ghetto.
couldnt you just put caulking or liquid nailso n it then screwit into place teh caulk arond it???
it doesnt leak around the terminal. if it did thats an easy fix. try this. take the terminal and put your mouth around where you attach the wires. put your other hand behind the terminal on the other side and blow air through. you will feel air going through the termianl from your mouth onto your hand...air leak.
why not just drill a hole, put a threaded bolt thru the hole, then put a rubber gasket on the inside, put ring terminals on the wires from the speaker, bolt them to the inside, and have it stick out the outside with a wingnut... a few drops of caulk\hotglue will keep the bolt in place, and the gasket will seal the hole up tight. and use the outter part of the bolt for the terminal.
cost you like $2 fora pair of bolts (if you dont have some lying around) and some wingnuts (for ease) and some small ring terminals.
and quite easy and airtight.
not a bad plan
almo181
Juggalo
almo181
Sasktoon (been there for 2 months)
almo181
