Tell me what you think
  • 2
snfsh79077
Ladie's like my pole
I'm working on a design for a guy on another forum for a single sdc2.5 12 off 500rms. Its for a single cab f150. I'm going to have the sub firing forward with the port firing towards the passenger wall. I want to use an aeroport but have never designed a box with one before. I understand that you can get away with less port area when using aero ports, am I correct?
Anyway here is the design so far. Tell me what you think and what I should change.
Box:
13.5 (H) x 42 (W) x 9 (TD) x 10 (BD)
Port:
3" x 5.5" long (used precision sounds calculator)
That should give me roughly 2 cubes after sub and port displacement tuned to 38hz
3" 5.5" long? doesn't seem right.
more like 4" 22" long.
well according to precision sound's calculator for 2 cubes @ 38hz with a 3" port it should be 5.4" long with flared ends and 4.4" long w/o flared ends. Unless Im missing something.
I've never used aero ports but I feel like Im over analyzing something
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
515
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Without a photo this is the best I could come up with, note the "physical port length" is at 22.5" and if you measured down the portwall to get...
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
snfsh79077
snfsh79077
bay st. louis/baton rouge
snfsh79077
maylar
    Jun 2, 2024
    Jun 1, 2024
