technical help needed
cappy72
NY
my comps are a 4ohm set
I believe the 6.5 by itself is a 2 ohm driver.
I am looking to add a 4 inch driver to my current comp set (ef-61)
if I wire this 4inch driver in series with the 6.5 and increase the resistance will that cause any problems with the crossover?
well that is not possible... I believe I will have enough power so I dont think that is going to be an issue...
my main thought is.... is there any way that more power through the crossover and a different resistence is going to mess with it?
as far as i know the crossover is a bunch of resistors that will just cut off different frequencies.
cappy72
cappy72
NY
cappy72
