TC Sounds Underhung NeoRadial 18
ciaonzo
TheContinental
11,703
76
WI
18" TC Sounds beehive neo underhung D2
This is for the complete 18" driver in beautiful physical and mechanical condition, no scratches or dents. Loud as ballz and more than I need. Specs below. If interested, I have coils and parts to build this motor up into other awesome drivers. We can work out the cost of those parts through PM.
Qts .33
Qes .35
Qms 6.9
Fs 27.9
Re 3.01
Vas 233L
mms 279G
cms 116 um/N
BL 20.7
Sens 93.5 1w/1m
1k RMS / 4k dynamic
$750 shipped.
UPS Ground, CONUS only.
Phenomenal solution for a single sub setup that can sound amazing and get loud. Does not need all that much power to do it, but it will gladly take lots of clean power for better dynamics.
my next woofer will be similar to this.
i think its going to be slightly better than the driver i have.
not trying to spam your thread but id like to express why i think this is one of the best drivers made.
low mass per displacement!
excellent thermal abilities with the larger diameter coil!
Vs the longer smaller coil the coil(80mm 3" four layer for example) can handle the same power but ultimately provides lower mass from the ability to use a MUCH shorted former lowing mass to get the same thermal dissipation. its a win win. That being said beside the long coil driver being slightly less efficient you can still get seriously good thermal dissipation with forced induction cooling system designed to cool both the former and huge surface area of the coil.
this woofer is a STEAL at 750$
In case there's any doubt about the accordian surrounds, this is my 5200 with the same surround. They still stroke.
cant believe this is still up... i would've gotten this beauty if i had the cash, worst part is its not even that expensive for what it is! this is one of a kind!
p.s. is this magnet made for these? was it a prototype prior the 5100's?
Thanks. I believe the beehive motors were from the BASSMAXX days, also the TC Sounds PA-5000. There were different varieties but they were very common in extremely potent horns for concert venues.
dynImage
dynImage
very cool man, good luck on the sale!
actually got 2 5100's not long ago, free-aired them and they are pretty impressive, sounds pretty **** clean and i was surprised of its frequency range! its pretty **** huge for a sub, very extended and doesnt break out! Not your typical sub, cant wait to put them in a proper house.
I have a feelin the midbass punch on these would be killer!
its a real shame TC went out of business //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
657
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
ciaonzo
TheContinental
ciaonzo
WI
germanyt
