TC Sounds Motor's
its a short top plate
9 all the way
the gap is narrower than a typical TC9, at least it looks like it, 1" slug Y35 will fully saturate a 3/4" 1010 top-plate so after the 1st slug there its a clearance thing lol. Gap that tight would help lower Q though if the coil is dense enough to make good use of the extra stout flux field.
I've always read that the RLp was a variation of the TC9 motor. I'm no TC expert though. Any of you tc fiends have a TC2+ motor laying around? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
got a C in physics in college, u kinda lost me
Good info. If this was here a few days ago I could have deciphered what motor my Evo was. I read that it was a TC2 and a TC2+, but had no definitive answer besides what Shane told me.
I have what seems like a dumb question, but with XBL^2 its obviously an acronym (I know what it is, but Im not going to clutter the thread with that since its irrelevant to the TC). Is there a particular technology that TC stands for or is it just derived from TC Sounds name?
So, you think the Qes/Qts would be the same if I took the 3LM off of my LMS4000 and replaced it with a TC9? Gap is exactly the same between the two. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Q would definitely be lower with the 3LM, that's the reason the Q is so high on the SW8000's. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If magnets had the same charge, Q shifts should be minimal, and I'd like to point out that the LMT from the RL-s line has a tc9 top-plate and a qts over 1.00 lol. My Old school TC3LM 4K's have the exact same Q as my tc9 lms drivers
Gen 1 post-break in
Re = 2.8222 ohms
Fs = 22.8900 Hz
Zmax = 27.3518 ohms
Qes = 0.6362
Qms = 5.5296
Qts = 0.5706
Le = 0.8308 mH (at 1 kHz)
Diam = 208.2800 mm ( 8.2000 in )
Sd =34071.0096 mm^2( 52.8102 in^2)
Vas = 47.2054 L ( 1.6670 ft^3)
BL = 10.3802 N/A
Mms = 168.8843 g
Cms = 286.2579 uM/N
Kms = 3493.3530 N/M
Rms = 4.3926 R mechanical
Efficiency = 0.0836 %
Sensitivity= 81.2408 dB @1W/1m
gen 2 pre-break in
Re = 2.9618 ohms
Fs = 26.6445 Hz
Zmax = 25.0854 ohms
Qes = 0.7603
Qms = 5.6789
Qts = 0.6705
Le = 1.0287 mH (at 1 kHz)
Diam = 209.5500 mm ( 8.2500 in )
Sd =34487.7765 mm^2( 53.4562 in^2)
Vas = 25.9976 L ( 0.9181 ft^3)
BL = 12.2980 N/A
Mms = 231.8929 g
Cms = 153.8644 uM/N
Kms = 6499.2305 N/M
Rms = 6.8362 R mechanical
Efficiency = 0.0608 %
Sensitivity= 79.8554 dB @1W/1m
hmmm, so the 2nd/3rd puck is overkill, but used for clearance on most motors with 3/4 TPs(y35 mags) given the pucks are relatively wide? This would make the 3hps stronger with more saturation? I dnt know much about this stuff, but i used to read a little about farromegnetics, etc.
the 3HP makes use saturation wise of the top 2 ferrites
audio_phill
Walking TSP Encyclopedia
audio_phill
Small Town VA
audio_phill
