TC Sounds DB500 12
  • 4
audio_phill
Walking TSP Encyclopedia
1. Product: Title
2. Specs: Needs a surround, but still 100% functional. TC2+ motor with demodulation circuit, High excursion stamped frame,
Re = 3.3338 ohms
Fs = 27.4494 Hz
Zmax = 45.6175 ohms
Qes = 0.5150
Qms = 6.5322
Qts = 0.4774
Le = 1.9760 mH (at 1 kHz)
Diam = 254.0000 mm ( 10.0000 in )
Sd =50670.7504 mm^2( 78.5398 in^2)
Vas = 119.2946 L ( 4.2128 ft^3)
BL = 10.7122 N/A
Mms = 102.7859 g
Cms = 327.0707 uM/N
Kms = 3057.4431 N/M
Rms = 2.7138 R mechanical
Efficiency = 0.4501 %
Sensitivity= 88.5514 dB @1W/1m
3. Description/Condition: Used, in need of TLC, surround punctures and dings aplenty. tear it apart and use the motor, and frame fr a custom, your call lol. Whole sub for the price of a motor.
4. Price: : $65 shipped obo
5. Pictures:
yessir Motor is a tc1K motor, I have removed the surround in anticipatio of the new one, but if your in for parts that shouldnt be an issue I figure lol.
If someone buys this and a 2" LMS coil from zeuslicious, I could build you one hell of a low end sq monster! My HT 8 played flat from 16hz to 89hz in 1.8cu@26hz.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
594
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
audio_phill
audio_phill
Small Town VA
the9876543
    May 18, 2024
    May 16, 2024
