Sold Tc Sounds 12" Dvc 4 Tc 2000 Tc2k
financethis
TC SOUNDS 12” DVC 4 OHM TC2K NEW
WILL TAKE $175 SHIPPED TO ANYWHERE USA
EMAIL ME DIRECTLY AT J_LOEB79@YAHOO.COM
12" TC-2000
Qts 0.264
Qes 0.284
Qms 3.72
Fs 20hz
Res 3.12Ω
Ls 2.41mH
Lp 5.62mH
Rp 4.86Ω
Dia 240mm
Vas 77.3l
mms 265g
cms 228.5um/N
bl 17.2T*m
Spl 85.5dB
12TC-2000 11.25" 12.65" 0.65" 8.25" 0.12ft3 33.40lb
Specifications
What makes the TC-2000 The New Standard for a high performance 500 dollar driver for only 325 dollars? See what�s inside that makes it the best solution for those who are ready to take on a reference level of bass!
Advanced FEA Motor System
� Double stacked 1" tall ferrite magnets and bored T-yoke for long throw
� 190oz top grade magnet structure
� Anti-flux modulation copper shorting ring to lower distortion
� Low carbon steel used for the gap plate and t-yoke
� Large pole vent for lower distortion and cooling capabilities.
Advanced high excursion soft part system
� Dual high excursion 10" linear roll poly-cotton spiders
� Intergraded woven leads to prevent lead-slap
� 3" diameter, 4-layer aluminum wire voice coil with an anodized aluminum former
� Extra spacing in-between spiders for lateral stability
� Single or dual 3.1Ω (4 ohm nominal) voice coil configuration
� Lightweight brushed and powder coated aluminum cone
� 1" wide long throw, highly durable NBR surround
� High quality thermal flexible epoxies to ensure longevity
Patented custom cast aluminum frame
� Extra clearance under the suspension for dynamic high excursions
� Wide spider landings for higher than average throw
� Patented detachable method for easy and fast and recones or repairs
� Durable high gloss black powder coat and chrome vc mesh guards
Performance
� Effective motor force of 98 Newtons2 per watt (BL2/Re)
� 800 watts continuous power (2500 watts peak)
� 28mm BL XMax (voice coil, one-way)
� 41mm XMech (mechanically limited, one-way)
financethis
financethis
Kansas City, MO
financethis
