Tap off Cigarette Lighter for Amp Remote Wire?
Didn't you say you never hooked anything up to the amp? Hook up some speakers and test it again with the gray wire.
What amp is it?
i have a Sony SD15X, i think thats what it is, it has a blue LED light on it that turns on when it gets the signal but i get nothing from it even when i had it hooked to the Gray wire, and yea i hooked subs up to it to see if that was the problem but nope still nothing
maybe i just blew a fuse in it and it wont start idk
Yeah you must have blown a fuse, check the fuses some how, thats usually a painful task. Check inside the fuse panel and see if theres a map that tells you what is what. Usually they fuse the constant power wire inside the fuse panel? I'm not sure where they fuse the switched ignition switch wire.
Some circuits do have a constant draw, if there is a load that uses it, like radio settings, but it's not a battery pushing out that voltage...
797
164
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
829
DaBurner
DaBurner
Long Island, NY
Ruffy
    May 20, 2024
    May 20, 2024
