Taking Bets....
Yikes. Why not just set the speaker inside the box, instead of bothering to cut a hole and mount it? Unless, of course, you plan on using it as a port later. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
not quite the same. if i port the box then it should be able to move like mad and i will still get the positive effects of a ported box, being that the sound wave will be slowed down through the port to make (nearly) the equivilent of two speakers.
that defeats the purpose of a ported box
3 cubes is right. whats wrong with having no "back pressure"?
The sub will move too much, you'll destroy the suspension before anything else. A smaller box would work better, if you play the sub at the box's tuning frequency it will make the most sound w/ the least movement.
If you mount the speaker in an enclosure larger than the VAS of the speaker, it will act as if its playing free-air anyway. This size box has got to be way over that 4" speaker's VAS. Add to that grossly overpowering the speaker by hundreds and thousands of watts, and you might as well just hook it to the wall socket with no box, it will have just about the same results.
X2 pointless.
somekook
only 15"s
somekook
Daytona Beach, FL
UndercoverPunk
