T20001bd on an L7
you guys think a RF T20001bd be to much a 15" L7? i know the l7s can handle a shi+ load of power but i have the birthsheet of these amps and then bench around 2800. i'm talking about with all the gains at 0
On my amp, if you put the gain on 0 you will have serious clipping. Turning them to 6 is nearly off. But I think that is what you mean.
I think that amp would be good as you got plenty of headroom so you won't have to push your amp hard.
Good Luck
cause it makes most of its power at 1 ohm. and it's not .5 stable
But if you hook it up for .5 at the subs your not really gettin .5 after the rise so the amp should be fine........youll be over 1 ohm easy.So whats the problem really.
I think that Rockford is made good enough that it will take it.If not get a Kicker:D
They make thier power at 2 ohms;)
good point i never thought about impediance rise. i also was thinking about getting a kicker. i 'll just have to wait and see.
talon2nr7588
talon2nr7588
Indiana
vetkilr
