t20001
boomzabit
The RF t20001 is what i call a high quailty amp, i wish i would bought this over my 1501bd even tho the 1501bd is a very nice amp, but i was looking through birsheets and what not on the t20001, and it puts out the same power at both 2 ohm and 1 ohm. Are their any other amps like this, now i know why they charge so much for the t20001
Don't know what birthsheet you were looking at, but the RF Power T20001bd does not (should not) put out the same power at both 2ohm and 1ohm. Power is increased when running a 1ohm load with that amp.
^^x2 i got the 1001bd and at 1 ohm i get full power //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
first time i seen that it doesn't say that in my r.f manuel??where did you get that amp?p.s why is you're efficiency at 69% thats low for rf //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif mine is 85% //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
that amp is not mine, i wish it was but it does same power at both 2 and 1 ohm, little bit more at 2 ohm, your t20001 doesnt do the same thing ?
i just got word from the owner the amp is rated at 1500w, but as we all see the amp is a bit underrated //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif RF done good with this amps, sorta like a two in one deal
uh no that amp at less should do 2000 watts not 1500watts //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif may be 2500rms but not 1500 go to the web pag at rockfordfosgate.com //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif what year is that amp i think the old rf power stuff where 2 ohm and the new is 1 ohm so you're right my bad //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yeah, that's either not a T20001, it's been photoshoped, or something is wrong with that amplifier. Efficiency is seriously low (should be in the 75-85% range), and power output should not decrease at 1ohm. It should be substantially higher @ 1ohm.
That is.
I've seen T3 birthsheets swing from 60%-88%. There are a crapton of them on TP.com.
-Nick
That is.
Seriously? I know I haven't seen as many birthsheets as you have, but I haven't seen any with much below 75%. Christ, I could pick up a class A/B and have quite a bit more than 60% efficiency.
boomzabit
boomzabit
Minnesota
boomzabit
michigan born
    May 14, 2026
michigan born
    May 14, 2026
