t-line/tapped horn design help. paypal ready
  • 4
Hello.
I need help to design/cut sheet a big t-line or tappedhorn for 4*18" to my walled vw caddy.
Someone with much experience with that kind of enclosures, or can recommend someone ?
Ordered a design from Jason evans at mobileenclosures but havent heard anything from him //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Best regards Andreas
I hope those 18" sub's have a high fs. I don't think a tline for 4 18"s would fit in a excursion. To put it in perspective I'm working on a tline for a 8" its a three cubic foot + enclosure. That's a large ported enclosure for a 12" sub. But hey make a build log if you do manage a design.
Even if they had a high fs it ain't happening. Chris made a joke about doing a tline for my 18 with an fs of 17. Came out to 199.5" of port length. Not to mention your port has to be the same as your cone area I believe.
Subs has fs29hz.
Okey i have no experience with tlines but the enclosure can be build quite big, maybe not big enough .
Max dimension is about W.46" H46" D49"
How about tapped horn? 30hz is low enough for me ?
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
The preamp input on most amps is 10-20k ohms, so you don't really lose voltage. I've run plenty of systems off 2v preamps with no problems.
a_niklasson
a_niklasson
uddevalla sweden
a_niklasson
