System Upgrade - 1999 4runner
Savackz
GA
I have a 1999 4runner with a 12" kicker comp and a rockford fosgate 250W prime. I was thinking about getting 2 10"s (Kicker Comps as well) and a rockford fosgate 500W prime Class-D with a sealed case. I don't want to go over 400$ but there is a little room. I was wanting some input on the subject about the system. I listen to trap music and rap mostly so bass is important.
The Rockford Fosgate I was going to get is only 130$ compared to the 210$ and it produces good base, I was mainly wondering what are some good 10's (I want 2) I could get under 120$ a piece. I had in mind Kicker's, but open to suggestions.
I would almost bet that one of these NVX subs would be louder than 2 400w kicker woofers. Given it is in the correct box.
Two of these would work as well on the amp I already suggested.
Incriminator Audio I Series 10" 300w Subwoofer
I guess I am nervous about spending that money and then not like it, I just need to hear it before I buy it :p
You can trust me it will be much louder than the current set up. A lot of guys here would say the same. Plus, it still comes in underbudget
I will look more into those! What type of box without building a custom should I get regardless of cost?
i have no experience with component speakers. Maybe someone else can help in this area.
DIY system turned out not that good....... 2014 Honda pilot (No metra Kit) so I have to keep factory HU I cut wires behind head unit and ran...
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
319
668
Savackz
Savackz
GA
bmk6795
