its the same shit if youve never done a ****** flush in an automatic. there are so many detergents in new ****** fluid that doing a ****** flush on a car thats never had one before, is going to result in leaks galore. it doesnt create the leak, but it takes away the filth that was gunking up the leak.synthetic is better //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif it doesnt thicken as bad as reg oil in the cold, it offeres better lubrication, and it runs cleaner, it also lasts longer then regular oil.
only issue is using it in high mileage engines that have been running regular oil, the regular oil creates buildup around certain seals, and switching to synthetic will clean this away.
if youve heard that synthetic can cause leaks in a high mileage engine....its not exactly the case, the proper wording would be "it makes a leak thats already there "technically" appear"
Hopefully you understand this better than the inner-workings of a car dealership.If you have a new/JUST rebuilt engine for the first 50hrs of run time use minerial oil, there after use synthetic.
I could explain it all but I really dont feel like typing a page and a half.
WTF is your problem???? "Hopefully you understand this better than the inner-workings of a car dealership."Hopefully you understand this better than the inner-workings of a car dealership.
And there's is no answer to this question. It's a matter of preference, and what the engine needs. Synthetic can be too slick for some engines, and I don't mean because of the miles. Just an FYI, this forum is a HORRIBLE place to ask for maintenance and repair advice.
From AutoMedia.comAre synthetics worth the extra cost? Universally, the answer is yes, whether for a high-revving turbo motor or an older engine that gets little use. Using another vivid comparison, French champagne is also worth the extra expense over sparkling wine, but it comes down to matters of your taste and bank account. Note, too, that most auto manufacturers do not specify synthetics, so unless you're one of the few who need synthetic oil, rest assured that you're doing no harm with good old-fashioned crude as long as you follow the owner's manual recommendations on viscosity and grade.
Do your own research though. Stay away from websites that sell oil, or related product, and also oil manufacturers. They're all biased towards synthetics, based upon the fact that it's much cheaper to make, and it costs a bit more, hence, makes them more money. Try bobistheoilguy and check out the forums. Lots of killer info in there. And please, don't get me wrong, I'm not saying synthetics are inferior. I run conventional Castrol GTX 10w30 in my car, and Castrol Syntec in my wife's car. I'm not partial to either one, I just think that it's not a clear cut case. Just like DSL vs Cable, or Turbo vs Sueprcharger. It's all a matter of purpose, needs, and budget.From AutoMedia.comNext, oil changes. The PAO base stock does hold up longer than petroleum-based oils, but the additives in both wear out at the same rate. The oil companies have tested their synthetics for longevity, but they still recommend following the specific owner's manual for oil change intervals.
Yea no one knows anything but you...except you really don’t answer his question.Again, this is the worst place to get car advice, thanks to know-it-alls like SuperchargedRS. He's the prime example of a god **** moron. He probably drives an 80s Camaro, or a Civic. There is no true answer to your question. It's a matter of needs, wants, and budget. It's also a matter of service designation. Call an auto parts store, or dealership, and find out what the service designation of the recommended oil for your car is. Then go to an auto parts store, and get that kind of oil.
