switched audio stuff and is not working right? HELP???
2010cory1992
Be for i switch i had a orion hcca 15.4, on a power acustik 5500, rms=3200 lol maby it got 1000!
but i had an extra battery!
Now i switched to 2 dc lvl5's, with a autotek mm4000.1d, 2000watts to each... with one battery and when i turn it up it will start sound like crap, it's tund right too. sooo this can be coused by not enough power right???
i also got 0gauge wire hooked up!
If i get two kentik hc 2000's in my car and a 180 amp alt it should sound right, right???
i see this ending bad.
You dont have the proper electrical to run that amp and send clean power to the subs. Why did you get the lvl 5's? Two of them on a 4k isnt very much power for em. The 4XL's would have been a better choice imo...
Are you sure your ground and other conections secure ? You will need a few batts and alt for sure but that may not be the complete problem I wouldnt play them without adding the alt and batts and big three. Might want to invest in more runs of 0 gauge to your runnin a lot of power and its still not enough for the subs you have But you must take the power into consideration when you build the box and tune it
2010cory1992
2010cory1992
Avondale,La
Varinabassing
