swiss audio sdx 1000c broken rcas?
i just traded something for it so i need too.. i heard it was a preatty good amp does .5 if on good electrical. fixing rcas wouldnt be to hard so it would be worth it
Id just get a new amp... Swiss stuff isnt worth fixing lol
incorrect. swiss is decent. if its what he can afford then thats it, now OP you can simply add in new rca's. do you know how to solder??
get a RCA chord with female ends, cut and strip the wire, then solder the wire inside to the board where the old RCA jacks where. just take those off, then you can runt he wire through the hole for each rca so you dont confuse them and mix them up. thats last resort if you cant find a replacement part
thanks for the help! im really trying to just get a whole piece because i want it to look flush but thanks you for not hating.. at least im not runnin boss or someshit its preatty hard getting nice **** w/o a steady income and all the other things i need to buy..
Now coming out to the wholesale distributor, Sub sonic car audio new brand owned by selelectronics since 2000. Look for new subs ,amp, empty...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
217
dutchmaster
dutchmaster
syracuse new york
dutchmaster
maylar
    Jun 2, 2024
    Jun 1, 2024
