swiss amp
Swiss Audio was a sister company of Audiobahn, Swiss Audio amps did not do rated power so it would be hard to say what it really puts out.
Some do. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
ive opened it and it says on the motherboard SMR6004 wich i looked for on the net and gave me almost what i have here, i can't find my amp and iv tried for a long time this looks exaclty like mine exept i have the two handle i've translated the page too and doesn give me precise detail about it imma still keep on searching thanks
http://images.google.com/imgres?imgurl=http://forums.drom.ru/attachment.php%3Fattachmentid%3D599819%26stc%3D1%26d%3D1250060475&imgrefurl=http://forums.drom.ru/70/t1150926475-p22.html&usg=__stTwEyq3Ox0BYn09bkwwgBdypoY=&h=480&w=640&sz=78&hl=fr&start=19&um=1&tbnid=_jbZfYXU-lVZyM:&tbnh=103&tbnw=137&prev=/images%3Fq%3Dsmr6004%26hl%3Dfr%26rls%3Dcom.microsoft:fr-ca:IE-SearchBox%26rlz%3D1I7SUNA_fr%26um%3D1
Here it is
4-channel Class A / B amplifiers MosFet
Technische Daten: Specifications:
* Leistung an 4 Ohm: 4 x 150 Watt RMS Power at 4 Ohms: 4 x 150 Watts RMS
* Leistung an 2 Ohm: 4 x 300 Watt RMS Power at 2 Ohms: 4 x 300 Watts RMS
* 2 Ohm Stereo stabil 2 ohm stereo stable
* variabler Lowpass: 50 - 250 Hz, 18 dB Variable Lowpass: 50 - 250 Hz, 18 dB
* variabler Highpass: 50 - 250 Hz, 18 dB Variable High Pass: 50 - 250 Hz, 18 dB
* variabler Bass Boost: 0 - 18 dB, 20 - 50 Hz Variable Bass Boost: 0 - 18 dB, 20 - 50 Hz
* Phase Shift: 0/90/180° Phase Shift: 0/90/180 °
* S/N Ratio: > 100 dB S / N Ratio:> 100 dB
* Line Out Line Out
* inkl. DUAL UV-Meter und Voltmeter incl DUAL UV meters and voltmeters
* Abmessungen: 480 x 206 x 60 mm Dimensions: 480 x 206 x 60 mm
the two handles come with the amp. Either way the amp sucks, i bought 4 bnib and two fried upon first turn on, the others fried at the rated ohm load. You might get 500w on a sunny, clear day.
Well, I've worked on a few Swiss amps, most of them fried due to strapping failure. (See the SDX2000D that's been passed around, which recently died due to hot California heat + direct sunlight and operation, causing the filter capacitors to explode. Quite violently too. It's up and working, just someone needs to pay for the repair. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif)
Once payday comes //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
friday it will be there.
chrisstlaurent
chrisstlaurent
gatineau, qc
BushJ311
