Surges and hovers
audiobahnuser18
Alright guy's i need some Help i have a 1989 Lincoln Mark VII And i need some help It runs good when your just driving it around giving it gas etc... all normal but when u let it idle with pressing no gas or brake it idle's at 15mph is that right? another thing is when you go to put it in park it starts to surge lights flicker and engine starts to hover , now sometimes it will do that for a little bit then shut off or other's it will just keep doing that.....what could it be i checked the manual and it said check for a tune up or pcv valve but i have changed all that pcv is like brand new and tune up i only did about 3 months ago. it just now started doing this because winter hit but in the summer it ran great . or sometimes when it's really cold it will just start to surge and hover as soon as you go to start it but that is only when it's really cold out....please some one help me i need help bad i need to figure this problem out
p.s. has brand new battery in it also
try cleaning the iac motor with some brake cleaner if that doesnt work
check your tps or throttle position sensor voltage it should be at .98 with the key
on not running.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
audiobahnuser18
audiobahnuser18
Mi
phantom240
Mike Mccabe
