Sold super nice high watt 4 channel amp.... look
tribaljames
sold local thanks for your time..............................................................
# Thunder 4-channel Super Amplifier featuring patented class A/B output
# 100 watts RMS x 4 at 4 ohms, 200 watts x 4 at 2 ohms
# 400 watts RMS x 2 bridged output at 4 ohms, 800 watts x 1 front/rear summed output
# Wired EBC Remote Subwoofer Bass Level Control Included
# Xtant Technology Cooling (XTC) - Thermal-regulated turbo-charged fan intercooler
# PrizmEFX accent lighting effects - Customizable to match your vehicle's interior
# Semi-unregulated MOSFET power supply
# Overload and thermal protection
# StreetWires connection terminals
# Variable electronic crossover at 40~350 Hz, selectable 12 dB Hi/24 dB Low Mono, defeatable
# Bass boost at 40 Hz, 0~18 dB/octave variable
# A.R.C. (Active Resonance Control): Cut 0~15 dB/octave, Freq. 200 Hz
# Input (RCA connection): Low-level, hi-level w/Smart Engage
# Input sensitivity: 100mV-1V/1V-10V switchable
# CEA-2006 Compliant
# Dimensions: 20-11/16" L x 9-5/8" W x 2-1/2" H
* Number of Channels 4
* RMS Power (4 ohms) 100 watts x 4 channels
* RMS Power (2 ohms) 200 watts x 4 channels
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power 400 watts x 2 channels
* Total RMS Power 800 watts
* Peak Power Output N/A
* Minimum Impedance Unbridged 2 ohms
* Minimum Impedance Bridged 4 ohms
* THD at Rated RMS Power N/A
* Speaker Level Inputs N/A
* Preamp Outputs Yes
* Built-in Crossover High-pass (HP), Low-pass (LP)
* High-Pass Crossover Frequency 40 - 350 Hz
* Low-Pass Crossover Frequency 40 - 350 Hz
* Subsonic Filter N/A
* Signal-to-Noise Ratio N/A
* Channel Separation N/A
* Bass Boost 0 - 18 dB
* Bass/Gain Remote Yes
* Fan Cooled Yes
* Fuse Rating N/A
tribaljames
tribaljames
poho mi
tribaljames
