Sundown SAX 200.4
skdooley
Sundown Audio SAX 200.4 amp.
I am the original purchaser and owner of this amp. Amp was purchased this past Spring from woofersetc for $580 shipped and was used for a front stage/sub stage install. Pushed 100 rms per front channel @ 4 ohm and ~700 rms on the rear channels bridged @ 2.8 ohm. Amp was grounded to the rear frame of the vehicle, gain was set using the DMM method. Only markings on the amp are on the mounting feet where the amp was fastened down. The amp was mounted across the back of my rear seats with the feet atop 1/2" MDF blocks, leaving a space behind the amp for the internal fan to breathe and move air efficiently. The amp will come with all original material that it came to me with. Manual, bass knob remote, packaging, etc.
The price is $450 shipped, inside the U.S. Will trade for a Sundown SAZ 1500D + $200, SAZ 2000D + $100, or a SAZ 2500D right out, all in similar condition.
Amp will be shipped in all original boxes the amp was shipped to me with, even the original packing peanuts.
If I had the cash I would seriously buy this this is a great price for a 200.4 thiese things are hard to find and only woofers etc has it for the price u said I have about 5 amps I need to buy first so this won't even be here //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Zapco c2k-2.5x? Rated 75x4 @4ohms. Does much more and sounds amazing doing it. Amazing damping and slew rates for extremely crisp distortion-free highs and low end authority and control that makes you think you have much more power than you actually do. The best amp I have ever had or heard. Also has crossovers to go active, fan cooling, and clip indicators for easy set up.
467
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
skdooley
skdooley
Roanoke, Virginia, United States
skdooley
    May 16, 2024
    May 16, 2024
