coolahan 10+ year member 141.6 dB @ 36hz 1,279 0 Oklahoma Mar 21, 2009 #1 has anyone tested the sae-1200d @ .5 ohms? is it stable for daily use? Click to read more...
R roarzorz 10+ year member lulzorz 2,674 28 vag Mar 22, 2009 #2 It is not recommended to run the Sundown sae amps @ 0.5ohm. If you must run @ 0.5 then get an saz-1500d. It'll do it all day long.
denim 5,000+ posts SSAudio.com 33,766 425 SSA HQ East Mar 22, 2009 #4 It is not recommended to run the Sundown sae amps @ 0.5ohm. If you must run @ 0.5 then get an saz-1500d. It'll do it all day long. Click to expand... I agree.
3 350zspl 10+ year member CarAudio.com Veteran 4,241 11 WPB Florida Mar 22, 2009 #5 i run my saz at .5 with proper electrical understand warranty is void have not tried an sae at .5 however
sundownz Pro Seller Supporting Vendor 11,349 95 North Carolina Mar 22, 2009 #6 No. It was not designed for that. You will eventually damage the amplifier - may be fine for a while but don't do it.
