Sundown. Sa-15 d4 or d2?
Im stuck on which to get i have a cheap Hifonics zues 1500.1 for now idk if it puts out close to rated power but its fused at 140a . . I dont plan to run a second sub so Id run at 2 ohm but dont want to leave anything on the table? Also my box is a pre fab audioenhacer 3.36cu^3 40/35hz
Its not the best i know but for the Sa15 which would be better with my setup ? Dual 4 @2ohm or dual 2 @1ohm
Thanks
It popped an 80amp fuse in about 10 seconds at 1ohm with Ofc 4ga then I put in a 125 and it was fine but the battery lead before the fuse still got a little warm. . @ 2ohm no power drain issues at all though
AudioMan4Life
Ithaca,NY
AudioMan4Life
