chevyfrk417
Hi everyone im new to the forums I hope I am posting in the right area if not the I apologize ahead of time my name is jesse im from indiana I have a 2006 Monte Carlo LTZ with 75000 miles ive only had it for about 4 months and i love it so far but here's my problem I recently purchased a sundown sa-10 d2, a audiopipe apsm 1300 im running 21' of 4ga power wire 3' of 4ga ground wire I am using a scosche loc2sl lineout converter hooked up to my rear speakers I have a 80amp fuse within a foot of the main fuse block under the hood I am getting 14.5 volts to the amp I have a clean ground on the strut tower my sa10 is reading 1.8-2ohms per coil I have it wired parallel so its at 1ohm the apsm is 1ohm stable I built the ported box to sundowns specs and I have a scosche 500k mini cap in line with the amp I know its not really worth using but i got it for free but my problem is the sa10 is 600rms and I have it wired to 1ohm and the apsm is rated at 1000rms @1ohm and from everything i have heard/read it puts out close to actual power but my sub is not putting out any real power I have adjust the gain, bass boost, and lpf on the amp and the subs cone doesn't even barely move just slightly vibrates it doesnt move air out of the port either any help is greatly appreciated you can pm me if you want I will answer any questions as soon as possible
SA-10
SA Series
APSM-1300
APSM-1300 - 1000 Watt Mono MOSFET Mini Design Amplifier
LOC2SL
Lineout Convertor-adjustable 80 watt | by Scosche
SA-10
SA Series
APSM-1300
LOC2SL
