Sundown Audio 12' sub amp help.
subarru
OP what's your electrical like? That Audiopipe at 1 ohm might be little taxing. I run an MB Quart 1200.1 at 1 ohm on my 130 amp alternator and I could use an extra battery...
I have a bus so no problem //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The Power Acoustik says it does 2k but I would be skeptical. The AP should be fine to push them and unless you have a Prius then you should have no problems. What car are you running? I ran a AP1500 in my Caliber and in my Jetta with no problems and I'm running a Rub2500 in my FJ with a 100 or 110a alt with a stock battery with a little drops. I added a second battery run between 1700-1800w @ 1 with no problems at all.
i have a subaru outback sedan. and as for the electrical it is all stock. and i know its a typo but if you balance the amp on the top of the car, you should be fine.
subarru
subarru
Windsor CT
OmegaBunny
