dwpjr
Background: I am using a Sundown 1500 to run two Sundown Zv1 15's dual 2's. I have this in a Suburban. I have the stock 140 amp alt. with two regular Autozone batteries under the hood, and two C & D batteries in the back. I've done the big 3(really 6) with 1/0 wire. I have one run of 2/0 welding cable from the front to the back. My main ground in the back is 2/0 welding cable coming off the cassis to one of the C & D's. I also have an MB Quart 80X4 running 4 6.5 component sets. The Sundown keeps going into protect even when the voltage is 13.5. I have replaced all cheap "ring terminals" with tinned copper lugs. All wire running to the Sundown is 1/0 OFC except for a couple runs of 1/0 CCA, none more than 5 feet long. I have replaced fuse holders, checked every connection, etc. I can't find the problem.
I have very cheap RCA cables...cheapest ones Walmart sells. could they be causing the problem? When I unhook the power from both amps, and connect it back, I get a spark. Should that happen? It seems that after that spark, the Sundown works for a few minutes, then starts going into protect again.
I'm pulling my hair out because I had this exact same setup in an Expedition with only one battery under the hood, and none in the back. My voltage would drop into the low 11's and never ever go into protect.
Help me please!!! lol
