Suggestions on Efficient Amps at 1000W
jda
KC
Probably has to be at 4 ohms, but any ohmage is OK. Money is not an issue, but want to keep the stock alternator... so 1000@ at 50-60% at 1 ohm is not going to work. 1000W at 4 ohm at 88% should be fine.
Suggestions?
I have a Kicker 1500.1 and JL 1000/1 laying around, but neither of those are too terribly efficient. Thinking about buying a T1500-1bdcp if nobody has any better options.
Thanks in advance.
an efficient 1000 watt amp is the MMATTS 1100.1 it will actually do 1100 watts. I have it in my eclipse and it slams. I am runing it off the stock alternator and 1 yellowtop battery.
uh.... My mmats is 95% efficient at 4 ohms //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif now now /Thread
Depends on what you are using it for //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif At full tilt it is still 76% efficient //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i highly doubt real world efficiency will be anywhere near 88%
What you talkin' bout Willis? You must have missed this post:
MMATS amps are the sh*t......
by the most knowledgeable guy on the forum, obviously speaking from immense experience with MMATs...................even though he's never owned one. But i bet he has a great "my buddy" or "a guy i know" story. What a llort.
I'm sure it's a true fact //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
xD
10
872
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
647
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
You might get some inspiration from the install that I did... Delta Audio Install
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
871
jda
jda
KC
Ge_off_me
