Suggestions for amp whine
soderdna
So ive rewired my system and even purchaced a new deck but I still get the allternator whine. So now ive established that the amp running my speakers is causing it. Is there a way to fix it? Its getting power and grounded right to the battery which is in my trunk so its not a lenth issue. Could the speaker wire wrapped around the rca's trick work for the amp? Or is my amp just toast, possibly from hot swapping?
try a .5 farad cap up front (close to the alt) if it's the alternator that is causing it
How would I wire this up?
how do u know its the amp for sure? also what brand is the deck, is it pioneer?
Its a brand new JVC Arsenal KD-A815 ive never had a problem with any JVC.
Double check your ground wire from the amp, make sure it is in a good location, and all the paint is removed.
My battery is in the trunk from factory, amp is wired directly to ground terminal
Lots of things can cause whine. Here are some:
-Bad ground at head unit
-Bad ground at amplifier
-Multiple amps grounded to different locations
-Bad head unit e.g. Pioneer with blown pico fuse
-Bad ground somewhere in the big 3
-Bad alternator (this was my problem - my DC Power alt took my whine completely away even without new wiring)
-Noisy component in car e.g. fuel pump
-Bad connection somewhere, either in the cable or the connectors
Check your grounds. Try running a portable CD/MP3 player directly into the amp. If that doesn't show the problem then try a ground loop isolator on the RCAs. Amazon has one for like $6, Prime eligible.
-Bad ground at head unit-Bad ground at amplifier
Ive thought of this, as my deck is grounded to the harness, but when it is grounded to the frame, the whine is louder and it makes a pop when it turns on.
Both amps are grounded at the battery with a block
not possible, brand new deck, JVC.
probably the cause, ive thought of re grounding my alternator to see if it could solve it.
it's a possiblity, my car is only 6 years old though and im the only owner so probably not but you never know...
also a maybe, with the car off and the deck on, if i turn the key to on, i can here the fuel pump cycle.
rewired everything this winter, triple checked.
This seems like my only option, if the alternator it self is not the cause.
The source of ground in a car is the alternator casing. It grounds to the engine via the bolts/bracket it attaches with. Most cars then ground the engine (elsewhere) to the frame. Ideally you should tap the ground right from the alternator's casing, but that can be hard to do if all of the bolts for the alternator are on the front and thus near the accessory belt.
soderdna
soderdna
Strathroy
joshy629
vegang
vegang
