sufcient wire
dvrmstrng
if i had one run of 4 gauge running a opti1400D (1000 watts @ 1 ohm)
and then a run of 8 gauge running a usamps1600.2 (200x2 @ 4 ohms)
each with their own respective fuses...
i had the opti in my car with 4 gauge that wasnt a problem, i was just wondering if adding a second run which would be 8 gauge to run the 1600.2 would be ok?
also big 3 will be done in 0 gauge shortly thereafter
yeah I think it would be easier to do a run of 1/0 and then you could use the free 8 ga to hook up the smaller amp after the d-block and you could just save the rest of it for future use...I used some 8 ga today putting my old kenwood back in while my jl is being repaired...i think it had been sitting in a box for like 5 years/
so what do you guys suggest...a separate run of 8 gauge for just the 200x2 amp...or run 1400 watts off of a single run of 4 gauge with a distro
dvrmstrng
dvrmstrng
DE
dvrmstrng
